Logic Board bad or good?
If I need to replace the logic board where do I get it?
Your diagnostic LEDs indicate a failed power supply. This is Apple part # 661-4670: iMac Intel 20" 2.4/2.66 GHz EMC 2210 Power Supply
Here's how to install it: iMac Intel 20" EMC 2133 and 2210 Power Supply Replacement
The video card will be either 661-4672 ATI Radeon HD 2600XT or a 661-4673 ATI Radeon HD 2400XT
The logic board is 661-4675
If you are now getting a light on #1 & #2 but not three, reseat the video card. LED Startup Sequence LED #1 = Power available. If no LED is visible: • Verify AC source • Verify known-good AC cable is connected • Verify cable connection between AC inlet and power supply • Verify cable connection between power supply and logic board • Verify power supply LED #1 + LED #2 = Power available, and system is powered on. If second LED is not visible when power button is pressed: • Verify power button connection to logic board • Verify power button functionality • Verify cable connection between power supply and logic board • Verify power supply • Verify logic board LED #1 + LED #2 + LED #3 = Power available, system is powered on, and video card found. If third LED is not visible after power on: • Verify that MXM video card is seated properly • Verify logic board
Pretty sure the 2.66Ghz only came with the HD 2600 card
welovemacs listed both, I try not to make these things up
NP, I would never expect you to post anything that you did not believe to be accurate. I have not seen a "standard" config with that combo nor seen any info suggesting its a custom option. That said maybe I just haven't come across it yet :-)
To know either hardware or software faulty, just pull-out the hard disk and switch-ON the computer. Display the BIOS setting for a while. If computer do hanging the problem came from hardware (logic board). If not the problem came from hard disk (software) or hd itself was faulty.
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 3,600
8 commentaires
To answer that correctly we need to know the exact model of your computer. What makes you think its bad?
par rj713
Please give the last three letters of your serial number for identification. Your logic board may also be able to be repaired. By the way, I've never seen a failure of a board on this model.
par mayer
ZE3 are the last three of the serial... The issue is as follows... The Power LED comes on when the power button is push the 2nd LED Flashes on then off immediately the fans twitch with this Flash and the system sits no further response.
par lseltun
Apple iMac "Core 2 Duo" 2.66 20-Inch (Early 2008) Specs
Identifiers: Early 2008 - MB324LL/A - iMac8,1 - A1224 - 2210
par mayer
I removed the hard drive and the system no get the second LED to light and the third blinks but there is no video....
par lseltun
Voir 3 commentaires en plus
