Aller au contenu principal
Le téléphone-avec-stylet phare de Samsung et successeur du Note8, mis sur le marché en août 2018. Muni d'un écran de 6,4 pouces et de stockage interne allant jusqu'à 512 Go.
104 questions Voir tout
note 9 sim pick into the mic hole
Hello, a similar situation to the one described here : Microphone could be damaged? but with the samsung note 9.
A sim pick tool was introduced into the microphone hole by mistake. Consequences? On the mic? On the waterproofness?
Is the physical arrangement the same as for s7 edge (in the example above) ?
Thank you.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
3 Réponses
Réponse la plus utile
I have heard that no harm will come to the mic. Worst case you have pushed into the rubber seal.
Indice 1
As long as you didn’t go too far the mic should be fine, but the IP rating would technically probably drop.
Indice 0
3 commentaires:
Thanks for your answer! How exactly could I test the mic? Since it's not the one used in conversation... More, I have left the phone for 20 min under 10cm of water. No problem.
par
If it isn't the one used in convo, you should be able to test it by recording a video
par
use samsung voice recorder in interview mode.
par
I poked both the mic and another hole near the sim slot by mistake. All seems to be wrong. Could there be any damage to the one near the sim slot. And what is it for. Can I help?
Indice 0
1 commentaire:
Working* not wrong :)
par
Ajouter une réponse
No Azerty sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 2,877
