Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
L'iPhone 5c d'Apple a été annoncé le 10 septembre 2013. La réparation de cet appareil ressemble aux modèles précédents et nécessitent l'utilisation de tournevis et d'outils pour ouvrir. Disponible en tant que GSM ou CDMA / 8, 16, 32 Go / blanc, rose, jaune, bleu, et vert.
Questions au sujet de 1577 Voir tout
iPhone does not charge and there is water damage - how to fix?
My iPhone does not charge with most cables (sometimes it works but very rarely) and the battery dies very fast. I send it in because it was still under warranty, but they sent me this picture to show there is water damage (so they can’t repair it).
Is the damage irreversible? Can I fix it myself? Which guides should I follow: change the battery, the docking station, what to do about the water damage?
Thank you!!!
Répondu ! View the answer J'ai le même problème
Ajouter un commentaire
Kits pour Nintendo Switch
Une solution rapide pour reprendre le jeu
Acheter un kit pour Switch
1 solution
Solution retenue
Apple’s water detectors trigger even when there was no liquid but a really high humidity. Basically, it’s their way to say “F you!” and make you buy a new phone or parts that worth just as much as a new phone. Just send it to third-party reputable repair shop and ask them to take a look on your 5C’s USB port, if replacement (that you can make) won’t help or you’re afraid to go deeper (that can also needs to be done in some cases).
And check more cables on your phone or those cables that didn’t work on other devices. If they still don’t work, then it’s just straight bad luck and you got faulty cables. Is they work as usual (it also means that they charge as fast as usual), then you might consider replacing USB port.
About those practices: https://www.youtube.com/watch?v=_XneTBhR...
Instruction on replacing Lightning port: Remplacement du connecteur Lightning complet de l'iPhone 5c
Cette réponse a-t-elle été utile ?
Commentaires:
Thank you for the help!
par
Ajouter une réponse
Myrah sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 18
