Screen is black after repair
My screen is not functioning after repairs.
It’s very important to always isolate the battery before disconnecting/reconnecting the screen assembly. The issue is that the LCD connector has pins that have high voltages (i.e. the backlight is ~20V) and ground in very close proximity. When you fumble around trying to line up the connector plug to the receptacle, you can short out the voltage rail and cause damage to the components in the backlight circuit. If you’re lucky, then only a backlight filter is damaged but other times, the entire circuit could be affected. Either way, this type of repair requires micro-soldering and isn’t really a DIY repair.
To test for this, plug your device into a charger or an iTunes enabled computer. Then shine a bright flashlight on the screen. If you can see a dim image, then the backlight circuit has been damaged. If you can’t see an image at all, then it may be the LCD circuit that is damaged.
If iTunes doesn’t recognized the device than the problem is more than just a screen or backlight issue.
I think that’s exactly what happened, thank you.
So the if there is no picture on the screen then all of the connectors for the screen on the logic board need to be replaced, am I correct?
Hi Nick,
Closely inspect all the LCD Connectors to make sure they are correctly plugged in.
Otherwise it may be your LCD Display chip.
Try inspecting all connections inside the iPad making sure they are all correctly plugged in and mounted down properly and let me know.
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 118
