Aller au contenu principal
La version seulement Wi-Fi de l'iPad Air deuxième génération d'Apple. Modèle A1566.
213 questions Voir tout
Ipad Air 2 touch ID not working after screen change
Hi all,
Changed the screen on a ipad air 2, which you need to remove the touch id home button & flex from the old/damaged screen to place on the new, but after doing so the touch id no longer works, I have double checked the connectors, flex etc and see no signs of any damage so not sure what else to check.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Have you tried it with the original screen to see if it works?
Indice 0
Unfortunately the most likely situation with this iPad is that the home button was damaged when it was removed from the original screen, and this cannot be repaired. If it does not work as a home button you can either replace it or use the 5 finger gestures.
iPad Air 2 Home Button and Gasket Assembly
Image iPad Air 2 Home Button and Gasket Assembly
Produit
$19.99
Indice 0
1 commentaire:
Note, the replacement button will only act as a home button, not touchID
par
Ajouter une réponse
colin sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 415
