Aller au contenu principal
Repair guides and support for gas and electric hot water tanks, boilers and household heat exchangers.
Questions au sujet de 29 Voir tout
Power issues in water heater
I recently replaced my thermostats and elements in my water heater but it's still not functioning properly. Everything is connected the right way but for some reason I have a constant 120v to my lower element and when the thermostat kicks in I get 240v. When the top element kicks in I still have the 120v to lower element. Any fix or test I can do the figure out the problem?
Update (12/29/2018)
It's a Rheem 71 40d b
Répondre à cette question J'ai le même problème
Indice 0
3 commentaires:
What country do you live in?
par
USA.....illinois
par
Hi @tbone42 ,
What make and model are the thermostats?
par
Ajouter un commentaire
1 Réponse
The heating elements are wired incorrectly or a thermostat is malfunctioning. It sounds like the bottom element is grounded to the shell somewhere, and whichever power line isn't releasing contact.
This can also happen if one of the power line wires and the neutral wire are crossed.
Indice 0
3 commentaires:
Heating elements are wired in correctly and the thermostats are both brand new. I also replaced both heating element 6 months ago.
par
The water heater is also 240v so there is no neutral.
par
If you don't have a neutral wire connected to the water heater, something is finding a neutral connection through the plumbing. This can also happen if you're measuring voltage in reference to ground. If an element has 120 vac across it's two terminals, either a thermostat is malfunctioning or something is not right with the wiring.
par
Ajouter une réponse
Michael Shayne Bradley sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 366
