GPU running slower than normal
I’ve been refurbishing 2011 27” iMacs for a while now and I’ve come across 2 logic boards with a strange symptom. Both of them cause the GPU to run at 100MHz instead of the normal 680MHz. Everything else on these boards functions properly. I’m thinking there’s a voltge or current problem but I don’t know what to check.
Any clues?
What does Diagnostics tell you?
par Dan
Nothing out of the ordinary. The GPU operates at full speed on other logic boards. Only benchmarks like Luxmark, Unigine or Cinebench indicate there is a problem.
par tpluth
I'm talking about Apple diagnostics. Restart the system and press the D key
Mac startup key combinations
par Dan
Yes. AHT did not report any errors.
par tpluth
I'd be curious to know what the GPU temperature is on the affected motherboards and a known-good motherboard.
par Steve
Afficher 1 commentaire en plus
