Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Can't find a reliable place to buy this motor.
I’m working on a roomba-like vacuum cleaner that ran over one of those sticky mouse traps, so the owner put it in the dishwasher. Anyway, I cannot find where to buy one of the motors pictured below without buying in bulk (30,000+ pack) from a manufacturer. If anyone could find where I can buy one, that would be great.
with or without the encoder board is fine.
Only thing on it is:
STANDARD MOTOR
RP390-ST/20143/DV
SMHD216804 RoHS
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Commentaires:
I’m searching this motor too…. Where i can buy it?
par
Ajouter un commentaire
2 solutions
Solution retenue
If the armature doesn't spin, soak it in WD40 for a couple days to free it up. Once it spins, use an ohm meter to check for dead spots. If a brush type, could have burned a winding. If it looks consistent, I'd disassemble motor and clean / lube everything.
Cette réponse a-t-elle été utile ?
Indice 2
You can desolder the PCB, but you need to know which is positive and which is negative or it’ll run backwards; motors do not care, but reversed polarity will result in reverse operation.
That looks like a pretty standard motor to me just from how it looks. If you can get the dimensions of it from the specific part number, finding a replacement won’t be hard. Just be careful how you remove the drive gear on the motor or you may break it.
Indice 1
Ajouter une réponse
Aiden sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 16
30 derniers jours : 49
Total : 2,078
