Aller au contenu principal
This unit cools or heats the water it circulates through the ChiliPad mattress pad. Model: CP-CUBE
Questions au sujet de 11 Voir tout
Cube is leaking from the bottom of the unit any suggestions?
The unit in itself still works cooling/heating but it is now leaking from the bottom of the unit doesnt appear to be at the connect hose
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Réponse la plus utile
I would suspect the hose connections as seen in step#5 of this teardown:
ChiliTechnology ChiliCube Teardown
To test use a small artist type brush and use a dishwashing soap and paint it around the connectors. If you get bubbles, you have found where the problem is.
Indice 4
3 commentaires:
Once you find the leak, how do you fix it?
par
Seal the crack with a good product like this:
https://www.amazon.com/J-B-Weld-8237-Pla...
par
I had to replace one of my Ooler hoses, they look to be food grade silicone. Easily bought at amazon but you have to figure out the size. I used aquarium tubbing to test, the silicone will be in soon.
par
Ajouter une réponse
bbqblisscatering sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 18
30 derniers jours : 102
Total : 4,404
