Aller au contenu principal
Repair guides and support for electric and stove-top kettles.
Questions au sujet de 40 Voir tout
The handle falls over
I have a 40 year old Asta stove top tea kettle and the handle falls over, so the wooden part of the handle ends up in the fire. The screws that attach the handle have been tightened, but what looked like rubber washers have broken down with age. What would be able to withstand the heat from a gas burner to replace the “washers” ?
Répondre à cette question J'ai le même problème
Indice 0
3 commentaires
Silicone is significantly more resistant to heat than rubber.
par
Thanks! Will try to track some down
par
Thanks to you both!
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Here is a chart to help you determine the inside diameter of washers:
https://www.engineering.com/Library/Arti...
The get a fibre or nylon washer set.
https://wbpartsexpress.com/5610-277-62?p...
Indice 4
Ajouter une réponse
MM Harvey sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 218
