HDD makes a click but doesn't read?
After turned on, the reader makes a click. it sounds like the gear is skipping and doesn't move. Does not show on the Finder but can be seen in the profiler as unknown device, showing both Fire wire speeds, 400 and 800. It is a Seagate 500 GB external drive, Barracuda 7.200.9.
1 commentaire
I found out that the logic board is burned. Since I can't afford the unreasonable thousands of dollars the data recovery companies charge, I decided to try to buy a lgic board from another hd, replace it and see what happens.
But I'm not sure if only the part from an identical HD is good or if another board from a similar would also make it.
My HD model # is: ST3500841A, Ultra ATA, 500GB. I couldn't find it so far on eBay or other vendors for a reasonable price. On ebay, there're many similar items but none are "Ultra ATA". There're mostly "Sata" and I don't know if it would fit. The models available are mostly ST3500841AS, which are offered at a reasonable price: $ 31.- to $ 39.- Do anyone of you knows the facts? Please.
par JORGE BARREIRO
