Phone not turning on
My phone is off and when I connect charger the led blinks 3 times and when I remove the charger and press n hold power button the white led keeps blinking but wont start the phone
Hello @RishabBhattarai,
Your phones battery is probably faulty. You may need to replace it. Do this by following these instructions:
There is a video tutorial here.
If you need any help please reply to this answer.
Thanks,
John
Hello dude,
Just had the EXACT same problem, solved it by opening the phone (2 screws to be removed next the charging port), disconnect the battery (just a small cable, it's easy af, many tutorials on youtube), plug the charger, reconnect the battery.
I read somewhere that it's due to a desync between the battery and the phone.
Good luck, I hope it'll be useful for someone ! I'm so happy to have repaired my phone <3
Hi I'm in the same shoes now Note 7 pro just shutdown I don't have idea how to pry open it
Tried the same, unfortunatly no luck, led keep blink for time and then stop and no charging =(
I am having the same problem. No idea how to solve it. Do you know any? Regards
i tried this solution but it didnt work for me. Its a xiaomi mi a2 one
I had the same problem, what I did;
I assume that phone and battery got out of sync again. But there seems no way to fix it. It seem to loose its sync again. To backup data the above is a procedure, but I will now send back the old phone and continue with the new, which is also double the memory :)
What if one of the screws are lost which is around the charging point?
Hi sir I need your help to get back my mi A2
I went to Goa that time my mobile display cracked and automatic functioned so I removed combo then keeped it but i afraid about battery so charger it everyday for 5 days all times mobile gets vibration and board ligts works, but i came back i charged it again at my home it's not vibrate or lights on, so I given to technician he told charging ic issue so ordered from online then i give him then after fix no improvement so I buy 2 sub charging board again same no any action, the final i insert the charger on mobile port mobile charging ic(board) getting over heat but mobile like a dead so please give me a correct guidelines please i am ready to visit any shop
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 42
Total : 15,419
