Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La gamme Mercedes-Benz 204 est une série de modèles de classe moyenne, la Classe C. Elle a été produite de mars 2007 à juin 2015 et a remplacé la série 203, construite depuis mars 2000. La fabrication de la berline s'est terminée début mai 2014. Depuis début février 2014, le successeur, la gamme Mercedes-Benz 205, est en production. La production du break a été arrêtée en mars 2014. Le coupé, dernier modèle de cette série, a été construit jusqu'en juin 2015.
Repair mercedes sam module at pc shop?
Actually i have an 07 mb e350, w211 body type, wasn't listed in drop down box. Trunk got wet and fried sam module/ signal acquisition module. This controls all car functions and are 3 of these which are connected to a fuse box on each. Can a pc repair shop do this repair. If the original from the car is repaired there is no need for any programming from a mb shop with the star diagnostic system. There are shops that do this but none near me. Also i believe at least 2 of the 3 of the sam modules have been affected. The other not by water but an improper battery change. Excessive arcing when connecting or disconnecting battery is apparently another main cause. My systems are all showing the tell tale signs, dash buttons and radio not working, system malfunctions on multiple systems etc. So would it be ok to ask a pc repair shop to perform this. I read a 64 pin, chip is the root of all this and bad design. Its just a computer board. Not a pc but i assume all the same components go into most circuit boards. Thank you. New sam units are expensive and still need programming, used would work if from exact same model but still need programming. Also most come from totalled vehicles which could have the same problem. Thanks, John.
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
1 Réponse
Solution retenue
Hi there!
If the PC repair shop has some normal people woking there they should be more than pleased to help you out with the SAM module. Not saying that they will fix it 100% but they at least can tell if the module is repairable. But if some water got in there that should just be a matter of soldering, cleaning and testing. I work in a PC repair shop and we do those kinds of things as well. Mainly because I have a car electric diploma :D!
Hope this helps!
Indice 3
2 commentaires:
What is the work of back Sam Mercedes Benz
par
@aluma Hey! Sorry for the very very late answer XD! SAM module controls all the rear electrical assembly... that is lights, door locks, sensors ext.
Hope this helps :)
par
Ajouter une réponse
John Bradley sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 49
Total : 4,816
