LCD replacement parts needed?
I replaced a broken screen on my ipad mini 2 the other day. Unfortunately while I was replacing it, my toddler “helped” me by placing his hand on the LCD. When I finished replacing the screen, and tried to power on, i had the white lines and black spots all over the lcd. When I went to the parts store to get a replacement LCD, there is a note at the bottom that says “LCD does not come with foam liner”.
What is the foam liner, do I need it, and where do I find one (couldnt find it listed in the parts store)??? Also, does it come with adhesive attached to it or do i need to get some (and if so what do I use, because that also wasn’t listed in the parts store)?? (Yes I know I need some adhesive strips for the screen then; I already have them in my cart lol.)
1 commentaire
What store are you trying to buy the LCD from? i think the foam they are talking about is the foam around the LCD, for adhesive i believe it has 2 strips on the underside that holds the LCD to the metal plate to hold it, otherwise it has 4 screws holding the LCD to the inner frame.
par Oscar C
