Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
Questions au sujet de 293 Voir tout
iMac 21.5 late 2009 blackscreen, gpu to replace?
hi folks
so I got this iMac EMC 2308 which can start but with a black screen. Diagnosis LEDs show me 2 LEDs lighted up, the 2 first I guess. I see them through the bottom of the iMac, at the right side of the RAM.
The screen doesn’t show anything even with a flashlight. Nothing happens when I plug an external screen. Bluetooth mouse and keyboard don’t connect to the iMac. Well I guess the GPU is dead, right?
Is there anything I can do/test to be sure of this pronostic? What do you think?
Thank you
B.ox
Répondu ! View the answer J'ai le même problème
Ajouter un commentaire
Manta Precision Bit Set
112 embouts pour toute réparation.
Upgrade Your Toolbox
1 solution
Solution retenue
Sadly, I think your logic board has died. This series uses two chips (North & South Bridge) for the South Bridge chip is responsible for the I/O to the SATA drives, USB, PCIe devices (WiFi) and Audio. This chip has failed.
Cette réponse a-t-elle été utile ?
Commentaires:
Does it change your feeling about it if I add that the iMac plays the starting sound on start up?
par
Sorry, I've seen this failure before and spent days tearing out my hair. I'm sure!
You are expecting the whole chip would fail, so f the audio is working how could the chips be bad? Here it's the other parts of the I/O circuitry that failed.
par
thanks dude. So need another logic board... ok.. I would never have guessed an issue of this kind by myself!!
par
hi there... so i bought a 2nd hand logic board and replaced the former one.. and the result is staying the same... so i hope you guys have a clue of what's going on because i really don't :o
par
Sounds like you got a bad logic board, return it and get your money back.
par
Voir 2 commentaires en plus
Ajouter une réponse
bruno bumbolo sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 48
