How to fix error c 32.11
i tried hitting the bottom diconeecting power and shaking it
This error code indicates that the tape itself is not moving and the unit has shutdown to prevent any damage to the tape. There are a number of possible causes for this since it is a generic error message. There can be a loading problem, or the takeup reel is not moving or there is no movement of the tape at all. In any case, this problem will require further investigation by a service provider. Without seeing the actual camera and investigating internally, there is little that can be done in this forum.
most likely is mechanical problem you may fix it if you are mechanically inclined the mechanism may need a good cleaning and a little oil and you are on your way to your recording I love my hvr z7
Nick y
Be very careful with oil in a tape unit. This is the most common cause of complete failure. Any oil where is shouldn't be often results in the tape adhering to the heads and other parts. I would NOT suggest using oil at all.
Dernières 24 heures : 2
7 derniers jours : 16
30 derniers jours : 74
Total : 946
