PS4 1215 stuck in safe mode loop
After completely tearing down my PS4 for a full clean up and thermal paste replacement, it just won’t start up.
It starts in safe mode and nothing seems to work, rebulding database just restarts the system, i tried initalising, updating and still nothing.
This happened a few times before but I would just reconnect the hard drive but not event that works this time, could it be my hard drive is just dead or something else?
3 commentaires
I would recommend just tearing it down again and rebuild it, making sure you get every connection and check every connection for damage as you go
par Tommy Gurreri
Will do it when I have time.
It seems that sometimes rebuilding database works and sometimes it doesn't.
When it doesn't I leave it off for 30 minutes and when I start it up again rebuilding works.
But it still boots in safe mode when I shut if off.
par Martin Knezovic
Try cleaning the contacts on the connector on the hard drive and insert the hard drive in the ps4 in and out a few times see if that helps.
If not it's either a failing hard drive or SATA controller on the board.
The hard drive health can be checked by plugging that hard drive into a desktop computer and checking the health via hard disk sentinel for bad, weak sectors or data communication errors.
par Ben
