Aller au contenu principal
Le smartphone phare de LG, avec une batterie coulissante et un module E/S amovible qui offre de nombreuses options d'expansion de hardware. Commercialisé en avril 2016.
Is it possible to replace a contact spring on Motherboard?
Hi:
I received an LG G5 model VS987 phone. It was reported the power button did not function but on closer inspection I found 3 contact springs on the motherboard that are broken- these connect with the power button on the back panel. I have safely removed the 3 broken contact springs, and removed three good ones from another motherboard for replacements. But, how can I safely solder the new contacts to the good motherboard? Anyone done this already?
Thanks!
Tom
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire
Thanks for your input…
Actually I`ve started researching SMD rework stations (uses hot air), that is how I will go. All this is still a bit new to me.
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Just use good tweezers and hot air at about 450c should do the
Indice 1
1 commentaire:
Is there a video you can post on where the motherboard is broken? I have the same issue with my power button which I've already replaced yet it is still not working.
par
Pièces et outils connexes
Tous les produits
Ajouter une réponse
Tom sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 247
