Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Galaxy J6, sorti en 2018, est le successeur du Galaxy J5.
Touch screen is not working after the update
Recently i changes my J6 display due to crack. Today i recieved the software upate and i updated it.
when the updat finish and phone restarted, the touch screen is not working.
What is the solution ????
Répondre à cette question J'ai le même problème
Indice 2
4 commentaires
Did you back up you'r phone before updating?
par
Nope. i did not expect that
par
Can you try plugging it into a PC and backing up like that?
par
how to fix it?
par
Ajouter un commentaire
6 Réponses
Réponse la plus utile
Could be a weird bug with the new update. If you can, try factory resetting the phone. You could have also just had unlucky timing and the screen just decided to die on you. Most likely it’s some kind of software issue.
Indice 1
Touch is not working correctly
Indice 1
Change original display ( combo )
See you your job done.
Indice 0
Hello,
At this point, presumably, you have already got a solution.
Just for the record:
You can connect a usb mouse using an OTG cable to operate the device. For backing up data, you need a bluetooth mouse to operate the device freeing the charging port to connect the phone to a computer.
Then you can enable usb debbuging and oem unlocking and go after a file to patch and fix the actual problem, without having to disassemble your device and avoiding the risk of losing your data.
Indice 0
The screen is totally off
Indice 0
There is no Drive app on my device
Indice 0
Ajouter une réponse
isfaak sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 30
Total : 3,170
