Internal SSD auto Unmounted, and issue in boot.
HI,
The internal SSD is auto un mount when it’s working.
Some time its appeared in the boot menu and some times don’t.
I used and external SSD to check the internal one appears when I started the disk utility the loading icon appeared then I got message internal SSD unmounted.
I dis assembled the SSD and cleaned the pads and same problem.
Any suggestions ??
Thanks in advance.
14 Mar
after trying diagnostics, I got VDH002 There may be an issue with a storage device.
for the battery I think it’s very good
13 Mar
DriveDX report
- SYSTEM INFORMATION ###
Report Timestamp : March 13, 2019 10:58:37 PM GMT+2
Report Timestamp (ISO 8601 format) : 2019-03-13T22:58:37
Application Name : DriveDx
Application Version : 1.8.2.610
Application SubBuild : 1
Application Edition : Standalone
Application Website : https://binaryfruit.com/drivedx
DriveDx Knowledge Base Revision : 9/9
Computer Name : MShokry’s MacBook Pro
Host Name : MShokry-MacPro
Computer Model : MacBookPro12,1
OS Boot Time : 2019-03-13T22:49:30
Time Since Boot : 00h 09m 07s
OS Name : macOS
OS Version : 10.14.3
OS Build : 18D109
OS Kernel Version : Darwin 18.2.0
SAT SMART Driver Version : N/A
ATA Command Support Tolerance : verypermissive
N of drives with S.M.A.R.T support : 1
- DRIVE 1 OF 1 ###
Last Checked : March 13, 2019 10:58:28 PM GMT+2
Last Checked (ISO 8601 format) : 2019-03-13T22:58:28
Advanced SMART Status : OK
Overall Health Rating : GOOD 100%
SSD Lifetime Left Indicator : GOOD 99.0%
Issues found : 0
Serial Number : S23CNYAG267607
WWN Id : 5 002538 900000000
Volumes : MShokryO
Device Path : /dev/disk0
Total Capacity : 121.3 GB (121,332,826,112 Bytes)
Model Family : Apple (Samsung-based) SSDs
Model : APPLE SSD SM0128G
Firmware Version : BXW1EA0Q
Drive Type : SSD
Power On Time : 190 hours (7 days 22 hours)
Power Cycles Count : 1,009
Current Power Cycle Time : 0.2 hours
DEVICE CAPABILITIES
S.M.A.R.T. support enabled : yes
DriveDx Active Diagnostic Config : Apple (Samsung-based) g-series SSDs config [ssd.apple.samsung.g]
Sector Logical Size : 512
Sector Physical Size : 4096
Physical Interconnect : PCI
Logical Protocol : SATA
Removable : no
Ejectable : no
ATA Version : ATA8-ACS T13/1699-D revision 4c
SATA Version : SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
I/O Path : IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/RP06@1C,5/IOPP/SSD0@0/AppleAHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice
Attributes Data Structure Revision : 1
SMART Command Transport (SCT) flags : 0x0
SCT Status supported : no
SCT Feature Control supported : no
SCT Data Table supported : no
Error logging capabilities : 0x1
Self-tests supported : yes
Offline Data Collection capabilities : 0x53
Offline Data Collection status : 0x0
Auto Offline Data Collection flags : 0x0
[Known device ]: yes
[Drive State Flags ]: 0x0
CURRENT POWER CYCLE STATISTICS
Data Read : 3.3 GB
Data Written : 318.3 MB
Data Read/Write Ratio : 10.55
Average Throughput (Read) : 24.0 MB/s
Average Throughput (Write) : 111.3 MB/s
Operations (Read) : 275,868
Operations (Write) : 17,510
Operations Read/Write Ratio : 16
Throughput per operation (Read) : 12.5 KB/Op
Throughput per operation (Write) : 18.6 KB/Op
Latency Time (Read) : 0 ns
Latency Time (Write) : 0 ns
Retries (Read) : 0
Retries (Write) : 0
Errors (Read) : 0
Errors (Write) : 0
PROBLEMS SUMMARY
Failed Indicators (life-span / pre-fail) : 0 (0 / 0)
Failing Indicators (life-span / pre-fail) : 0 (0 / 0)
Warnings (life-span / pre-fail) : 0 (0 / 0)
Recently failed Self-tests (Short / Full) : 0 (0 / 0)
I/O Error Count : 0 (0 / 0)
IMPORTANT HEALTH INDICATORS
ID NAME RAW VALUE STATUS
5 Retired Block Count 0 100% OK
173 Wear Leveling Count 0x700210012 99.0% OK
175 Host Writes MiB 1,697,281 (1.6 TB) 99.0% OK
192 Unsafe Shutdown Count 83 99.0% OK
197 Current Pending Block Count 0 100% OK
199 UDMA CRC Error Count 0 100% OK
TEMPERATURE INFORMATION (CELSIUS)
Current Temperature : 37
Power Cycle Min Temperature : 37
Power Cycle Max Temperature : 37
Lifetime Min Temperature : 32
Lifetime Max Temperature : 37
Recommended Min Temperature : 5
Recommended Max Temperature : 65
Temperature Min Limit : 5
Temperature Max Limit : 70
DRIVE HEALTH INDICATORS
ID | NAME | TYPE | UPDATE | RAW VALUE | VALUE | THRESHOLD | WORST | LAST MODIFIED | STATUS
1 Raw Read Error Rate Life-span online 0x0 200 0 200 - 100% OK
5 Retired Block Count Pre-fail online 0 100 0 100 - 100% OK
9 Power On Hours Life-span online 190 99 0 99 3/13/19 10:58 PM 99.0% OK
12 Power Cycle Count Life-span online 1,009 99 0 99 3/13/19 10:58 PM 99.0% OK
169 Total Bad Block Count Pre-fail online 0xFD02A001E0 217 10 217 - 100% OK
173 Wear Leveling Count Life-span online 0x700210012 199 100 199 3/13/19 10:58 PM 99.0% OK
174 Host Reads MiB Life-span online 3,383,194 (3.2 TB) 99 0 99 3/13/19 10:58 PM 99.0% OK
175 Host Writes MiB Life-span online 1,697,281 (1.6 TB) 99 0 99 3/13/19 10:58 PM 99.0% OK
192 Unsafe Shutdown Count Life-span online 83 99 0 99 3/13/19 10:58 PM 99.0% OK
194 Temperature (Celsius) Life-span online 37 63 30 33 3/13/19 10:58 PM 47.1% OK
197 Current Pending Block Count Life-span online 0 100 0 100 - 100% OK
199 UDMA CRC Error Count Life-span online 0 200 0 200 - 100% OK
DRIVE ERROR LOG
error log is empty
DRIVE SELF-TEST LOG
self-test log is empty
