Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le téléphone-avec-stylet phare de Samsung et successeur du Note8, mis sur le marché en août 2018. Muni d'un écran de 6,4 pouces et de stockage interne allant jusqu'à 512 Go.
How to replace the screen without frame?
Hello, does anybody know how can I replace the cracked screen on my Samsung Galaxy Note9 without swapping out the whole frame? Also, Where can I buy Galaxy Note9 screen replacement?
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
1 commentaire
I am replacing screen without frame because I want to save money & time. I could find any good guides on the internet so PLEASE Help me.
par
Ajouter un commentaire
4 Réponses
Solution retenue
I’ll just use the same procedure as the Note8, It can’t be that much different anyway.
Indice 0
Réponse la plus utile
You will probably not save time if you but a screen without the frame. The process of taking the screen off the frame is a long one if you want to do it somewhat correctly. Yes you can just rip the old screen off but that creates a huge mess (lots of small glass pieces everywhere). The way to get the screen off of the frame is to use a lot of heat to loosen all the adhesive holding the screen onto the frame. When I say a lot of heat, I mean a lot of heat. You will want the device to be basically too hot to touch then use a playing card to start and cut all the adhesive holding the screen on. While you will spend a little more on a screen and frame combo, it will be a much easier repair and probably take you less time as you won’t have to try and take a screen off then put a new screen back on the frame.
Indice 5
Why are you wanting to replace it without the frame? Using a replacement screen with the frame is much cleaner. The suppliers I use only offer the screen with the frame. The screens are actual samsung screens because they come in a samsung service pack.
I use injured gadgets and mobilesentrix.
Indice 1
3 commentaires:
par
Have you found any suppliers without the frame? A quick search brought up suppliers charging about 40 to 60 dollars more for frameless note 9 screens. The repair time may actually be less with the frame. Youll only have to transfer the board and charge port connector which I've done on Galaxy devices before in around 30 min tops. I believe the lack of guides may indicate that the repair with the frame is the prefered method among repair shops and DIYers. Ill look around to see, if I can find anything.
par
Has anyone found a video of replacing the note9 without the frame?
Indice 0
Ajouter une réponse
Dinan Blueje sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 35
Total : 5,637
