Aller au contenu principal
Sorti le 19 septembre 2014, cet iPhone avec un écran de 4,7 pouces est une version plus petite de l'iPhone 6 Plus. Identifiables par les numéros de modèle A1549, A1586, et A1589.
Questions au sujet de 5198 Voir tout
iPhone 6 no cell service
Hi.   I had a iPhone 6.    sometime over Xmas 2018, I took a iOS upgrade to 12.1.2 and I immediately had all sorts of issues with my cellular service.  phone works fine on wifi, but cellular service became non existent.    - when I went to settings, cellular, I didn't have a network selection option to choose.   Reset network settings helped, temporarily, as did a full hard reset.  I also tried backing the upgrade to 12.1.2 out and reverting to 12.1.1.       I have read the reports of phone being bent, re-seating  the cellular antennae etc - I did all those things, and re-seating the antennae.  They all appeared to help.  Temporarily, but  24 hours in, my service vanished again.   Makes me think it was the turning off and turning on that helped temporarly, not the actual actions I took.  I use my phone for my business, so as i’d had the phone several years,  I decided it was time to bite the bullet and change it.
I got myself an iPhone 7, and 3 months in, I had the exact same symptoms - no coverage.    This time, there was no apparent catalyst - no iOS upgrade anywhere near it.  it hadnt been dropped or mishandled in any way 9as far as i can tell).  I was able to take this one back to Apple and they tell me its a known issue (but only with the iPhone 7) and its gone off to be fixed.    It occurs to me, its a very similar issue to the one my 6 had, so if apple can fix the 7, presumably I can fix the 6.
Does anyone know what this known issue is so I can fix my iPhone 6.   (my 6 has had all kinds of new (non original) parts (battery(x2) , screen, BT &  wifi antennae, but all many many months ago) , so there is no chance apple will look  at it.
Any ideas where I should look?
Thanks in advance.
Craig
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
3 solutions
If the same problem appeared on two devices, and a factory reset didn’t help with the first one, then it seems that the problem is originating from your cellular network provider. I would call their customer support line because they should know that you have been paying for cellular network service, but have not been receiving any.
Cette réponse a-t-elle été utile ?
Indice 0
It is a known issue with the Baseband IC on the logic board, this is not a DIY repair. There are professionals that do this kind of work but it will likely cost about as much as buying another iPhone 6.
Indice 0
Thanks. Agree on the known issue - my 7just came back from apple with a new logic board. I guess I’m not fixing the 6.
Thanks for for the advice.
Indice 0
Ajouter une réponse
craig sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 38
