MBP 15" Late 2011: Display glitch, blue lines, shut downs.
Hi,
I’ve tried to find someone with exactly the same issue but couldn’t, so here I am, first time raising a question here.
I have a MBP 15” Late 2011.
I’ve upgraded about two years ago the ram and the hard drive for 16GB Crucial RAM and 525GD SSD Crucial drive (MX300).
Since a few days my laptop seems to start glitching every time I’m using a lot of CPU (I’m a music producer and I use often some CPU-hungry softwares). Sometimes it gets back to normal, some other times the display seems to shut down and goes black, but the computer seems to still be running and I have to force shutdown it. After two days with this problem the laptop started doing it more and more until it couldn’t stay on without this problem occurring every 5 minutes.
About 6 months ago, I had the infamous AMD GPU failure. My first thought was that it was related to this issue again so I went back to the Repair Shop that changed the GPU. After keeping my laptop for way too long they told me it wasn’t GPU related and advised me to change the SSD drive (but they didn’t look really convinced of the problem this time).
Some other thing I noticed a few days ago is that I had the “replace battery” sign on. Remembering that today, I took out the battery and tried to power it on. Surprisingly it was working all well. I was working on it for 4 hours and it was still fine so I then decided to test it by loading loads of CPU-hungry softwares and sadly the glitch issue happened again (but the display didn’t go all black this time and it ended up by stabilising after some heavy glitches).
I think I mentioned everything I could think of, so my question are:
Would changing the SSD really be the solution? (it’s still under warranty).
Would changing the battery be any help? (it’s about 7 years old now…)
Would changing the hard drive cable any help? I’ve read about the cable not being compatible with this SSD drive, if so, is this drive not suitable for this laptop?
Let me know if you need more informations.
Thanks,
Gabriel
3 commentaires
Define glitching, graphical glitches? I've been seeing a lot of 2011 GPU failures recently, and I'm still not convinced it's a HDD/SSD issue rather than a GPU or overheating issue. If it's fully shhutting down, try this guide and report back with the results if you're able: Comment déterminer les causes d'arrêt du Mac
par Jonah Aragon
Yes I'm referring to graphical glitches.
I haven't experienced actual power shutdowns, just display shutdown sometimes (I could still hear the laptop running and see the keyboard lights).
par gabriel
Hi Jonah,
@jonaharagon I did try this today but the code doesn't work. It says "command not found".
Today my laptop suffers shutdowns. Is there an other way for me to see the shutdowns causes.
To be more precise, the laptop shutdowns and tries to reboot, it stays on a white screen and the fans start to go crazy.
par gabriel
