Aller au contenu principal
Tutoriels de réparation et d'entretien pour les périphériques de jeux vidéo, comme les joysticks et les manettes.
Questions au sujet de 178 Voir tout
My generic PS3 gamepad won't stop vibrating when plugged into my phone
My generic ps3 controller works on both my computer and my Android phone, but it has two issues. It doesn't ever vibrate when I use it with my computer, and as soon as it's plugged into my phone it vibrates and never stops. As I said it's generic and pretty cheap, but I assume there is some kind of general fix that works with most gamepads. If not, is there a way to just permanently disable the vibration all together? I don't have any soldering tools, but I may be able to open it up to do something albeit not my preference.
Répondre à cette question J'ai le même problème
Indice 0
7 commentaires
Hi @skittlyrainbow ,
Does it do this when you plug it into another similar type of phone i.e. Android or iPhone?
if not perhaps it is a setting in the phone causing the problem. What is the make and model number of the phone?
par
I believe it happens when in another phone, yes. It's a Galaxy j3 crown
par
Also, the model number is SM-S767VL
par
Does that help?
par
Sorry if I'm being a little impatient, but has anyone found a solution
par
Voir 2 commentaires en plus
Ajouter un commentaire
3 Réponses
Réponse la plus utile
Hi I have the same problem with a Huawei P8 lite, pls help
Indice 1
If you want to get rid of the vibrating, hardware-style, open up the controller and disconnect the rumble motors.
Good luck!
Indice 0
2 commentaires:
Is there any way I can disable the motor without opening it up?
par
Unfortunately, I have no idea.
par
Go to the controller setting in your ps3 and turn the vibration to off
I hope this work
Indice 0
Ajouter une réponse
Skittlyrainbow sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 32
Total : 3,470
