Aller au contenu principal
Modèle A1297 / Processeur Core 2 Duo à 2.66, 2.8, 2.93 ou 3.06 GHz
998 questions Voir tout
Front Bezel- Frankenstein Replacement?
Has anyone tried replacing the front bezel of a non-unibody macbook pro 17 " with the front bezel of a G4 powerbook 17"?
From pictures the strucutre looks similar, however, there may be two potential issues: the camera and the hinges.
Please let me know if you had any experience with this frankenstein fix or know if it might work, thanks!!
Répondre à cette question J'ai le même problème
Indice -1
Ajouter un commentaire
2 Réponses
Réponse la plus utile
I've looked through the manuals for both and I will agree that they do look VERY similar (front, back and overall dimensions). I do not have both at my disposal so i cannot tell you if they will work or not. I would be curious of your results. The hinges shouldn't be a major issue, the camera might cause problems (as you also mentioned). You might have to dremel off some mounting tabs and use two sided tape to hold it in place.
Indice 2
Well, i think that needs some serious home engineering ;-)
As pierrej mentioned, a Dremel would be of tremendous value.
Indice 1
1 commentaire:
Thanks for the help guys! However, I chickened out of the experiment..finally found the piece online : )
par
Ajouter une réponse
Dagrosap sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 626
