Install the new HDD as usual and boot to your El Capitan install USB.
Enter Disk Utility and click your hard drive located on the left hand side to highlight it and then choose Erase
Enter a name for your hard drive (default is “Macintosh HD” but you can name it whatever you want.) and choose your format (usually “Mac OS Extended (Journaled)”) and GUID partitioning table. Exit Disk Utility.
Proceed to install macOS.
Once installed, you will be asked if you wish to transfer data. Connect your old hard drive to the MacBook Pro and then choose “From a Mac, Time Machine backup, or another startup disk”. and click continue.
Select the data you wish to transfer (typically everything), assign a password to the migrated user account, and then allow it to complete.
Once complete, disconnect the external hard drive and you should be good to go.
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
