I’m having a similar issue, but I don’t think it’s the battery. At least not the battery cells. I recently replaced my battery using an IFIXIT battery. I starting seeing the problem you’re describing, rapid drop in displayed battery charge, with my old battery. The Apple diagnostics indicated my old battery was ready for replacement, so I assumed the battery charge was actually dropping that quickly due to a failing battery. However, I’ve seen that happen with my new battery as well.
Here’s an example of how my new battery is performing. I was running off battery only and the displayed charge went from 100% to 72% in what appeared to be a normal rate of discharge. I had been using my MacBook Pro in a typical way; emails, web searches, image viewing, etc. To go from a displayed charge of 100% to 72%, it took ~ 1 hr 50 mins. At that time, the display jumped to 7%. My plan was to continue using the laptop until the battery fully discharged. I continued working for another ~ 40 mins and the displayed charge stayed at 7%.
I had to move on to something else, but left the laptop on. The display sleep was set to 7 mins and the computer sleep to 15 mins. I would wake it up every 15 to 30 mins, navigate a bit and then let it sit. The displayed charged stayed at 7%. I actively used the laptop for ~ 2 hrs 30 mins and then the sleep/wake up cycling for another ~ 1 hr to 1 hr 30 mins. The battery completely discharged sometime between the 1 hr and 1 hr 30 mins mark. I didn’t witness it.
So, I think that’s fairly normal battery performance, ~ 3 hrs 30 mins to 4 hrs running off battery only power. Therefore, I think the battery cells are performing fine. That leaves the battery charge sensing circuitry. I’m not sure if that function is performed on the logic board or the small circuit board on the battery assembly. I’m planning on getting a new logic board for another problem, so I’ll see if it also fixes the battery charge state display. I think the graphics card that’s built onto the logic board is having issues, as I’ve been having a problem with the screen randomly blacking out, while the computer stays running.
I tried to get a logic board from IFIXIT and a couple of other sources, but they were all out of stock. When I get a new one, I’ll post the results. If the battery charge sensing function resides on the battery assembly circuit board, then a logic board swap won’t solve the problem.
If anyone out there knows where the charge sensing function is performed, that information would be helpful.
I have an update to my situation. I did finally replace the logic board in my MacBook Pro (Retina, Mid 2012). That did not help the battery state of charge display. I've concluded that I received a bad battery from iFixit. My battery status already shows "Service Recommended".
A voté
Annuler
Indice
3
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
10 commentaires
It seems ifixit knowingly sold a lot of bad batteries. Replacing a mid 2014 MBP battery is a 50+ step operation to get the battery in, and then the same number of steps to put the unit back together again. The only way to know if you got a bad battery is to install it.
Take Apple up on its $199 OEM replacement, because odds are ifixit will send you another bad battery.
par MFMauceri
I have the same problem. Did you contacted Ifixit? Or did you fix the problem already?
par Jeroen
Hello, the same situation here!
par tjordanov
The problem is still there… my battery dropped from around 60% directly to 7%… maybe this is one of the consequences from relying on China… they produce defective products and we have to suffer.
par Asahi
Hello, Jacob, did you find out about the problem? I have exactly the same issue now. Brand new battery (second already) and battery level drops from around 60% to 7%, remaining for quite some tome on the 7% level after that.
Cheers, cal
par cal007
Voir 5 commentaires en plus
