Aller au contenu principal
En juin 2017, Apple met à jour le MacBook Air 13" avec un nouveau processeur Intel Core i5 Broadwell, ce qui donne une légère augmentation des performances et de l'autonomie de la batterie.
421 questions Voir tout
MacBook Air not charging, SMC reset temporary fix
I just got a replacement Megasafe 2 charger from Apple for my MBA (Early 2017).
However, often in the battery status drop-down, i see “Battery not charging” for which SMC reset should fix..
But in my case, it only a temp. fix, it next time i plug n again, “Battery not charging” appears in battery status again. So, very frustrating. This is also a new charger,but the LED keeps going dim, so i’m turning my attention to a port issue.
System Report mentions battery condition is : Normal and cycle count is only: 148.
Sometimes i can get it to charge though.
Suggestions to fix?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
What does CoconutBattery telling you on the batteries & chargers status? post a snap shot here for us to see Ajout d'images à une question existante
par
Ajouter un commentaire
2 Réponses
Solution retenue
If the MagSafe LED is going off and on then your I/O board board likely needs either cleaning or replacing. Try using a cotton swab (Q-Tip) just damp with some 85% isopropyl alcohol to wipe it down. Otherwise here’s the replacement part MacBook Air 13" (Mid 2013-2017) I/O Board
Image MacBook Air 13" (Mid 2013-2017) I/O Board
Produit
$79.99
Indice 2
1 commentaire:
check the i/o board or i/o flex cable. try to replace with new. my macbook air A1466 have problem with i/o flex cable.
par
I had the I/O flex cable and board replaced after spilling milk tea on it but this battery not charging issue happened after the replacement. My macbook was fine before that
@Enal Farid I have the same model and had the i/o board and flex cable replaced after spilling tea on my macbook but this battery not charging issue happened after that replacement sk what could be the problem?
Indice 0
3 commentaires:
You really should create your own question with all of your info.
I would add, how about getting a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Ajout d'images à une question existante that is if your system is able to run at all.
Liquid spills likely need more than just the I/O board.
par
I have already posted a new question with all details.
And my system is running just fine and all the data is still there too, no issues with the keyboard either, if you would like to know.
Currently my macbook is with the service providers and I can only pick it up after the weekend’s over.
Please do tell me more about this “gem of an app” that sounds very intriguing to me. @danj
par
@k__mas - Click on the blue URL link I posted to get to the app and what it offers.
par
Ajouter une réponse
na na sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 863
