Arne Büsing without knowing the actual panel number and only going by the information you gave us it looks like it is compatible with the following:
MacBook Pro 15.4" 2.0GHz Core i7 (A1286) - Early 2011
MacBook Pro 15.4" 2.2GHz Core i7 (A1286) - Late 2011
MacBook Pro 15.4" 2.4GHz Core 2 Duo (A1286) - Late 2008
MacBook Pro 15.4" 2.4GHz Core i5 (A1286) - Early 2010
MacBook Pro 15.4" 2.53GHz Core 2 Duo (A1286) - Mid 2009
Your panel should be one of these models
LP154WP3, LP154WP4, LP154WE3-TLA1 or LP154WE3-TLB1 if so, it’ll fit.
Cette réponse a-t-elle été utile ?
A voté
Annuler
Indice
3
Your systems specs: 13" MacBook Pro 2.53 GHz Core 2 Duo (with SD slot)
par Dan
Are you up to replacing the LCD panel alone? Or do you need to replace the full display assembly (case damage).
par Dan
I was planning to replace the full assembly. I don't have the tools to remove the glass, so buying a used assembly is the cheaper choice.
par Arne Büsing
Then you'll need the correct assembly part as there is enough differences in the part to prevent the substitution of the full assembly.
par Dan
