Aller au contenu principal
La version 2016 de la série d'ordinateurs portables Apple destinés aux professionnels. Dispose d'un écran Retina de 15 pouces, d'une résolution de 2880 sur 1800 pouces, processeur quad-core Intel Core i7, 256 Go / 512 Go /1 To / 2 To en options de stockage, RAM de 16 Go et un clavier équipé deTouch Bar. Sorti en novembre 2016. Numéro de modèle A1707.
258 questions Voir tout
My Display is working only in a certain angle
My Late 2016 MacBook Pro with Touch Bar has problems!
My internal display works only in a certain angle and doesn’t display in the 90 degree angle.
I have been using the same system using Airplay through my Apple TV and also using an external Display.
However not able to figure out the exact reason for the display not functioning.
Répondre à cette question J'ai le même problème
Indice 3
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Both the 13” & 15” 2016/17 MacBook Pro Touch Bar systems face the same issue its dubbed FlexGate!
Apple encountered a design defect that only showed up later in use with these systems displays. The cable that connects the display to the logic board backlight logic fails. Sadly, Apple has not fessed up on this defect and you’ll need to get your display replaced out of pocket, Ouch!
Here’s some good references:
Don’t forget to sign the petition here: Fix all MacBook Pro 2016 and later with stage light effect or backlight shutdown #flexgate
Save your paperwork! If Apple finally addresses this you should get a rebate.
Indice 2
Ajouter une réponse
Karthik Rupakula sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 15
Total : 5,423
