Aller au contenu principal
Processeur quad-core Intel Core i7 à 2,3 GHz, 2,6 GHz ou 2,7 GHz (Turbo Boost jusqu'à 3,7 GHz) avec 6 Mo de cache L3 partagé.
561 questions Voir tout
Samsung 860 EVO + Adaptor Compatible with A1398 MacBook Pro Retina?
I’m trying to upgrade the internal SSD on my macbook and wanted to know whether this combination would work?
SAMSUNG 860 EVO MSATA
https://www.amazon.es/Samsung-EVO-m-SATA...
MSATA ADAPTOR
https://www.amazon.es/LeHang-Tarjeta-ada...
Thanks in advance.
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
5 Réponses
Solution retenue
Why I do understand the desire to use a cheaper drive solution, I personally don’t recommend them.
You’ll find lots of people recommending them but you’ll also hear people like me who often need to pull them out as they have failed. Just last week I pulled out two having to put in a better solution which in the end costs the customer more.
The issue is the adapters people are using are not reliable and creates CRC errors which wears the SSD excessively. In addition the interface within M.2 SSD’s is not quite the same as what Apple is using in their custom SSD. As an example the sleep action your laptop goes into won’t work correctly.
Instead I would recommend using either the OWC or Transcend 3rd party SSD’s which have been designed to work from the get go. Or, find one of the custom Samsung SSD’s Apple uses.
Do take the time to review this: The Ultimate Guide to Apple’s Proprietary SSDs
Indice 2
I am currently running a similar combo. Qnine mSata adapter with a Evo 860 mSata 1tb, and the performance is great! No issues whatsoever. Its fast
Indice 1
1 commentaire:
mSATA is harder to obtain. It would be preferable to use an adapter from propriety board to SATA M.2 adapter. More options through there. SATA based SSDs work great, I know others won't recommend but I only stop there for 3rd party adapters. Don't like using PCIe third party adapters.
par
I tried it on 2 different 15’ Retina MacBooks, Mid 2012 and Early 2013 . Used the Samsung EVO 960 mSATA and it DID NOT WORK!!!
Indice 1
No, the 860 EVO is a SATA based drive. You will need an NVMe drive formatted to APFS to install MacOS on it. I’ve been using the intel 660p with my Macbook Pro with the Sintech adapter and it has worked very well.
Indice 0
2 commentaires:
Also known as a PCIE based SSD too for NVMe.
I don't bother with OWC as their SSDs imo are garbage with high failure rates. I'm curious to see how transcend does though.
par
Keven & @benjamen50 the 2012 MacBook Pro retina uses a mSATA drive.
Both a PCIe/AHCI or PCIe/NVMe drives will not work! Review the 'Ultimate Guide' I posted above as well as the interface diagram.
par
Also advice against an OWC drive. Had upgraded to a 1 TB OWC drive for my Macbook Pro 15 inch Late 2013. Drive failure after 25 months. Can’t remember that an original drive ( custom samsung) had ever failed in a macbook within that time period!
Indice 0
Ajouter une réponse
Anthony Perez sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 1,655
