Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le OnePlus 5 (OP5) est un smartphone de 5ème génération sorti le 20 juin 2017. Il s'agit du successeur du OnePlus 3T et du prédécesseur du OnePlus 5T.
After display repair the volume button is stuck, what's wrong?
Hey all,
I replaced the display frame on my oneplus 5, it seems to be working again but when I try to start the phone it boots in fastboot mode & keeps scrolling through the menu options. I can't select anything when it does that, though pressing volume down stops it from scrolling. When I hold down the power button for a few secs it powers down. It also does this without the backcover mounted so I don't think it's stuck.
I've already removed the motherboard once again to check out the connections under the motherboard. Could it be I reseated the connectors slightly off and that's what's causing the problem?
Thanks for your time!
Edit: When I hold down the volume down when powering on it starts up normal, everything works as it should be except the volume buttons. I can use volume down but volume up is unresponsive. Volume stays at set level, so it's not stuck always pressing volume down. I think I somehow broke it when I moved it to the new frame maybe? Still interested in your thoughts.
Répondre à cette question J'ai le même problème
Indice 3
Ajouter un commentaire
2 Réponses
I know i had a similar issue with a OnePlus 3T, the sidebuttons are just glued to the side of the frame on the OnePlus 5T aswell right?
Anyways, my buttons wouldn’t stick to the side very well so i put my own double sided tape strips there, but the strips were too thick and that made the volume up button get pressed all the time when i sealed the phone up. So i simply removed my double sided tape and used B-7000 glue instead and that fixed the problem.
Indice 0
1 commentaire:
I too have used double sided tape and though I have had the issue that it was too tight when I put the back cover on the problem I have now also exist when the back cover isn't on.
par
Just to answer this old question. The engineering on this device is very tight and even if the volume buttons are in place, they can still be slightly out, or the volume button on the back case may be out. To resolve the issue with the volume up button always being pressed when the phone is reassembled, I removed the volume button from the back case - pull back the white plastic tab slightly and the button comes out. I then used a fine bit of sandpaper to take some of the head from the tip of the volume button plunger, not much. Placed it back on the case, that did the trick and it now works as it should.
Indice 0
Ajouter une réponse
Joost Seitzinger sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 38
Total : 1,703
