After fixed iPhone 7 audio IC, the phone won’t charge
Hi guys, I have an iPhone 7 here. It has classic audio IC problem: Grey-out speaker and takes ages to load. As usual I removed the big audio chip, did the jumpers, installed the IC, then I started to notice something is not right: the phone is warm and took ages to load, the system is very laggard, and the phone wouldn’t charge. I disconnected the charging flex from motherboard, then the phone was back to normal, the phone was quick to start and everything seems working properly with the charging flex disconnected. I tried two new charging flexes, same thing happened. As soon as I connected the charging flex, the phone was warm and slow to start.
Because the phone worked fine before I did the audio IC repair. I thought somewhere is shorted under the audio IC. So I removed the big audio chip, however the pads looked fine. Nothing is shorted under the chip. I installed the audio IC back to the board. Again same thing happened. The phone is warm and slow as soon as I connected the charging flex. The phone would work fine with charging flex disconnected.
I want to ask, does the audio IC has anything to do with the charging flex? I checked the components around the charging connector. They all look good. None of them was disturbed.
Thanks in advance for any suggestions.
3 commentaires
Have you tried a known good battery? I have never run into charging issues after audio ic repair.
par Chris Stables
Yes I tried new battery, new charging flex. As soon as I connected the charging flex, the phone was warm and system was very slow, not charging is just one of the symptoms. The phone works properly without the charging flex connected. Something must be shorted when connecting the charging flex, but I don’t know where.
par phonestore.uk
Hey guys im having the exact same problem with 2 iphone 7. I have done like 90 iphone sounc ic and never had this issue, what was the solution?
par danbedin
