Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
A1418 | EMC 2889 | Late 2015 | 1.6 GHz dual-core Intel Core i5 or 2.8 GHz quad-core Intel Core i5. Released October 13, 2015.
Questions au sujet de 34 Voir tout
No power. LED 1 stays on. 2 and 3 will flash upon pressing power.
I’ve found several results on this page for similar problems but with different iMacs. This one has non-removable RAM though so RAM suggestions don’t help. LED 1 never shuts off until I unplug the system. When I press the power button 2 will light up, then 3 will light, and then both will shut off. They will continue doing this until I unplug power. It sounds to me like the logic board failure.
Répondre à cette question J'ai le même problème
Indice 0
Commentaires:
Can you give us some background on what happened.
Did you check your power outlet, is it correctly wired and have a proper ground? You'll need to also check your breaker panel's ground connection too! Do you have a surge suppressor or better yet a UPS.
par
Ajouter un commentaire
1 solution
Réponse la plus utile
Logic board was the issue.
Cette réponse a-t-elle été utile ?
Indice 1
Ajouter une réponse
Taylor Campbell sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 36
