How to switch hard drive on different fat models?
I bought two broken fat ps3s off ebay, one had the broken motherboard and no display and the other one was missing a hard drive. I tried installing the hard drive from the first PS into the other one following the guide on this site but the systems have different connectors for the hard drives? The PS I took the drive out of had the connectors facing forward and the second PS had them to the left. How do I properly install the hard drive into the second PS? They are both fat models.
EDIT: The broken model I’m taking the drive from is a CECHL03 and the second is a CECHG03.
4 commentaires
@retroadvance
post some images of those connectors etc or at least give us the data label from both of those drives. They should all be SATA drives
par oldturkey03
@oldturkey03 I only have one drive because the second PS3 came without one
par Dan Rafter
@retroadvance Duh, of course you are right :-). You mentioned that in your question. Can you post some pictures of the connectors? Here is the guide on how to post images Ajout d'images à une question existante
par oldturkey03
I'm not a ps3 expert however one seems to be a 40gb version and the other an 80gb version so I'm not sure if the drives are interchangeable so without pictures that may be the problem ur having
par c9679
