Aller au contenu principal
Repair guides and support for riding, or ride-on, mowers, also known as lawn tractors, of all types used in tending large tracts of land.
Questions au sujet de 712 Voir tout
I have a general wiring question about ignition wire harness?
I am actually working on a dixon ztr 308 zero turn mower and am wondering if I have to use a wire harness to connect keyed ignition switch or if I can wire strait from ignition to solenoid, magneto, and ground? Is the harness just for a quick disconnect?
Répondu ! View the answer J'ai le même problème
Commentaires:
Thank you for the confirmation all the wires were corroded and direct wired now with better quality wire. Runs great now
par
Ajouter un commentaire
Fix Kits pour Android
Remplacer l'écran ou la batterie est à portée de kit !
Acheter maintenant
Acheter maintenant
1 solution
Solution retenue
A harness is for consistent easy assembly at the factory. You can direct wire with a connector or not. The ZTR 429 I’m rebuilding wouldn’t engage the blade clutch, the connector was so badly corroded. I bypassed it using wire nuts. Now waiting on new drive cones to finish the rebuild.
Cette réponse est utile ?
Score 1
Ajoutez une réponse
Wesley Neal sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 20
