How to reset the tv
Need to reset the channels without a remote??
I found the manual online here: https://www.manualowl.com/m/RCA/R52WH74/...
You can use the buttons on the front of the TV to control the selection:
Front Panel Buttons
If you cannot locate your remote, you can use the front panel buttons of your TV to operate many of the TV’s features.
MENU/OK - Brings up the Main menu. In the menu system, it selects highlighted items.
CH UP - Scans down through the current channel list. In the menu system, acts like down arrow button on the remote control and adjusts menu controls.
CH DOWN - Scans up through the channel list. In the menu system, acts like up arrow button on the remote control and adjusts menu controls.
VOL < - Decreases the volume. In the menu system, acts like left arrow button on the remote control and adjusts menu controls.
VOL > - Increases the volume. In the menu system, acts like right arrow button on the remote control and adjusts menu controls.
POWER - Turns the TV on and off.
Complete the Auto Channel Search
The Channel setup screen lets you set your signal source and search for the available channels on that source. The Auto channel search allows the TV to search for all the viewable channels on both of your tuners—for digital or
analog channels—or on each antenna separately. This is sometimes called auto programming.
When you first turn on your HDTV, it's set to search on both tuners.
To search for channels on the both tuners:
1. Make sure the Signal Source is set to Both. If it's not, use the right arrow to change the setting to Both.
2. Press the down arrow button on your remote control to highlight Analog Signal Type.
3. Use the right arrow button to choose the signal type you're receiving on the analog tuner—either UHF/VHF Antenna for an off-air antenna or Cable.
4. Press the down arrow button on your remote control to highlight Auto channel search.
5. Press OK to start the Auto channel search on both tuners. When the channel search is complete, press OK to access the List & Labels screen.
Note:The Auto Channel Search looks for channels for the Signal Source you choose—analog, digital, or both. To perform the Auto Channel Search for just one tuner, choose that tuner in step 1 above. Then follow the rest of the steps.
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 1,512
