Aller au contenu principal
A series of 40 inch LCD HDTVs by Sony.
189 questions Voir tout
No picture, no sound, no blinking lights on Sony KDL-40W600B
Cannot turn on with remote or button on TV. Unplugged power brick, waited overnight. Applied power again. Got a brief Sony logo on screen, then it went dark. I have repeated the power disconnect/reconnect several times. Results always the same. No picture (other than the Sony splash screen), no sound and no blinking lights of any kind. I notice that after the splash screen the display has a very dark purple-ish tint until I remove power. Is this a bad board? Any help with which one, if that is the problem? Thanks in advance!
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
3 Réponses
Réponse la plus utile
@jazzbo "this “after the splash screen the display has a very dark purple-ish tint “ is most likely your backlight being on. This could very well be a mainboard issue. Post some pictures of your boards with your question so we can see what you see. Ajout d'images à une question existante
Make sure you have a multimeter so we can check a few things
Indice 3
1 commentaire:
oldturkey03, thanks for the fast response. I’ve added pictures of the 3 boards.
par
Hi @jazzbo ,
Since you get the splash screen and the unit stays powered on, I'm wondering if it is a software problem rather than a hardware problem. Which would also be on the mainboard where the problem may be as suggested by @oldturkey03
Here's a link showing how to update the firmware in your model TV.
I don't know if it will work if your TV's firmware is a later version or not.
You can contemplate attempting this as a last resort if all else fails to resolve the problem
Indice 2
1 commentaire:
Thanks @jayeff. If all else fails I'll give this a go.
par
It sounds like you have a faulty LD BOARD. Replace it you are good to go. just for emphasis it is the second picture you uploaded.
Indice 0
Ajouter une réponse
R Foster sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 618
