MacBook beeps but won't turn on after logic board replacement.
I replaced a dead 12” MacBook 2015 with a working 12” MacBook 2015 bottom assembly with logic board and battery (had partial broken screen that would boot).
After replacement, I connected to an USB-C to USB cable and using a 5-Watt iPhone charger for low voltage charge, I let it charge for 20 minutes then proceeded to try to power it on, it didn’t start up,
I switched over to the regular charger and managed to get it to boot up for around 3 seconds everything booted, screen keyboard lights, then it went dark again.
Now all I get is the beep sound when I plug in the cable and I get a beep sound occasionally when I try different SMC reset. I’m planning on leaving it charging over night by low voltage and checking it out again tomorrow.
Is there any guidance or suggestions to try'?
Did you follow this guide Applying Low Voltage After Every Repair (Retina MacBook 2015 Only) fully?
par Dan
