Aller au contenu principal
The Buick Lucerne is a full-size upscale sedan sold by Buick from 2006 to 2011.
Questions au sujet de 4 Voir tout
Car shuts off when warmed up
car starts and runs fine until engine heats up to operating tempature, then it stalls, it will restart but keeps stalling until engine cools down. What can cause this?
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire
I'm having this problem with 1992 Buick Century 3300. Shuts off when it reaches operating temp. I replaced the fuel injectors, thermostat, coolant temp sensor, and intake manifold gasket. Car still stalls.
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Hey akajuwan.
A failure with the Crankshaft Position Sensor, the Ignition Control Module, and/or the Throttle Position Sensor could cause intermittent stalling. That said, it’s important to check the wires and connectors (pins) associated with these aspects, as corrosion or physical damage, etc., to the wires or connectors could actually be the problem, and not the actual sensor or module.
Might be able to provide more helpful info if you would provide the details on your model.
Indice 2
Possible it could be a cracked distributor cap, when the car warms up cap expands causing fire to jump and run badly or not at all.
Indice 1
Ajouter une réponse
akajuwan sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 15
Total : 640
