Aller au contenu principal
Sorti le 16 septembre 2016. Modèle 1660, 1778. Disponible en GSM ou CDMA / 32, 128 ou 256 Go / Or rosé, or, argent, noir et noir de jais.
Questions au sujet de 2027 Voir tout
Sim not ejecting properly after housing replacement.
Hi, I done a housing replacement for an iPhone 7 but removing the sim try is very fiddly, the sim ejector does not sit flush with the housing, is there any way to fix this?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 solutions
Solution retenue
On iPhone 7 there is a small black pin that sits inside the housing that ejects the Sim tray and is often forgotten when swapping housings.
Cette réponse a-t-elle été utile ?
Indice 0
Commentaires:
Thank you this helped
par
Would you know where I could buy replacements of this?
par
Well if you're lucky and still have your original housing you can remove it from there, although to put it back into the new housing you will have to remove the board.
But as far am I as aware you cannot buy this part.
par
Well,
the real problem is you have used an aftermarket (fake) back off ebay.
They do not come with that hole predrilled.
So it could not screw the sim ejector in.
It can be done it just needs to heat the screw so it will make the hole.
Indice 0
Ajouter une réponse
Haris sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 62
