Aller au contenu principal
The NV360 model is part of the Lift-Away Navigator Series and can be identified with its global trade item number 00622356533225. It is a lightweight 2-in-1 Lift-Away upright vacuum with a detachable canister for portable cleaning power.
Questions au sujet de 9 Voir tout
Vacuum suction ok but green light won’t turn on and brush doesn’t spin
My Shark lift away turns on and suction is ok but green light doesn’t turn on and brush doesn’t move when I try to push the vacuum. Everything is in place ok and no blockage.
Répondre à cette question J'ai le même problème
Indice 3
Ajouter un commentaire
2 Réponses
Réponse la plus utile
have you checked the belt to see if it broke?
Indice 1
2 commentaires:
I can not remove screws check
par
On my NV251, the belt's in great shape (the vac's a few weeks new), used a few times and found the light out and beater brush immobile as well. I was able to open it up...that's what I found....nothing unusual (the screws do turn hard)...thoughts?
par
We found all ten screws, and finally got it apart. The belt was fine. I stressed it by using outside on dirty outdoor carpet with leaves. I may have damaged it because it made a high pitched sound. I removed blockages from hoses but the light at the bottom is red and the brush isn’t turning.
Indice 0
Ajouter une réponse
Danielle Klatke sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 970
