USB-C Port Replacement Difficulty
I was wondering if replacing the USB-C board actually requires soldering and board repair as it states here MacBook Pro Retina (A1708 Late 2016-2017) USB-C Board. A repair video for the previous model year shows a simple connector for the USB-C ports.
4 commentaires
If you are going to do the repair/replacement yourself, why not just open up the unit and see for yourself? :-)
par prop man
@propman Typically I would, however my boss would prefer to have the repair done by an Apple Tech even if it is not under warranty depending on the cost. I have another laptop with the same issue that is under warranty being looked at right now that I will ask what the repair cost would be without the warranty. Trying to get as much info as I can until I know how much a non-warranty repair will cost so I can determine whether or not I will actually be cracking it open myself.
par David Costantino
@dcost Sounds like a plan! :-)
par prop man
hi @dcost I know i'm late but I wonder how did you resolved it? i'm having the same problem w my macbook
par jverock99
