Aller au contenu principal
Sorti le 25 septembre 2015. Modèle A1687/A1634. La réparation de ce modèle est similaire à celle des versions précédentes et nécessite tournevis et outils pour faire levier. Disponible en GSM et CDMA / 16, 64 ou 128 Go / Argent, Or, Gris sidéral ou Or rosé.
Questions au sujet de 793 Voir tout
Are these the correct parts to replace the 6S+ rear camera lens
Does this part include the actual glass lens (or is it just the metal ring) and i assume I need an adhesive ring, this part?
If these are not the correct parts to replace a cracked 6S Plus rear camera lens please point me to the correct stuff.
Also can the lens be replaces from the outside with a heat gun (some you tube videos indicate it can)
Image iPhone 5 to 6s Plus Front Camera Gasket Pads
Produit
$0,99
Image iPhone 6s Plus Rear Camera Lens Cover
Produit
$4,99
Une réponse ! View the answer J'ai le même problème
Ajouter un commentaire
1 réponse
Solution retenue
the framing is “spot welded” onto the frame of the device. You can remove it but the trick is finding something strong enough to hold the new camera lens in place with regular use.
or you can remove just the glass lens if your lens frame is fine. I don’t recommend trying to do this without removing the rear camera however as a little bit of glass can fall onto that camera lens, scratch it, and make it so you have to buy a new one.
Cette réponse est utile ?
Commentaires:
Doe iFixIt sell the glass lens? I don't see it.
How do I secure the lens?
par
some kind of adhesive. b-7000 works well. or you could probably use some kind of epoxy maybe. just make sure not to use a whole lot of whatever you use as you don't want the glue to spread out to the lens or camera.
not sure if ifixit sells the glass lens or not
par
I just ordered this from Amazon and it comes with the adhesive ring
https://amazon.com/gp/product/B077M9K4Y6...
par
Ajoutez une réponse
Jack sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 17
Total : 23
