Aller au contenu principal
Sorti le 16 septembre 2016. Modèle 1660, 1778. Disponible en GSM ou CDMA / 32, 128 ou 256 Go / Or rosé, or, argent, noir et noir de jais.
Questions au sujet de 1285 Voir tout
iPhone 7 dead after lightning port replacement
Hi, it’s me again
After replacing the Dock and fixing the Speaker the dock and device are compleatly dead.
No Power, No Charge, No Recovery and No DFU.
I tried 2 screens, 2 Batterys and A newly bought lightning dock.
Im going to replace it and do some troubleshooting but if it still doesnt work im just going to sell it for around 100€ on eBay and get a Sony Xperia XZ or something.
~Xavier
Répondez à cette question J'ai le même problème
Commentaires:
So what's your question? Are you looking for help here or just stating facts?
par
I need help, but it seems like it's the battery. But I would still want to make sure
par
@refectio Or looking for parts customers
par
Ajouter un commentaire
Ignorez les nouveaux gadgets.
Take $10 off $50 with
SKIPANDSAVE10
Save Now
SKIPANDSAVE10
Save Now
2 réponses
Réponse la plus utile
I would start by testing a bare-bones setup. Start by disconnecting the battery first (always!). Then disconnect the digitizer, LCD, front camera, rear camera and home button extension flex. Now re-connect the battery; you should only have the battery and Lightning Dock flex connected. Connect a known-good, preferably Apple-original Lightning cable to an iTunes enabled computer.
If you have access to a multimeter, you could measure the battery first. If it reads ~3.8V - 4.2V, then it is good. Does iTunes recognize your phone? If so, then you should re-connect one flex at a time until the phone stops working. I would start with the Home button flex first, then add the rear camera, LCD & Digitizer then from camera flex.
If the bare-bones setup does not get recognized by iTunes, then you most likely have a logic board issue. You could send it (or find a local) to a repair shop that specializes in micro-soldering repair.
Cette réponse est utile ?
Score 3
you said you replaced battery and screen multiple times, yeah?
when you did the charge port replacement were you properly grounded/esd safe? possible you shorted out the main board with static
Ajoutez une réponse
Xavier Bury-Stäubner sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 20
Total : 20
