MacBook Air mid-2012: Random screen glitches and lockup/crashing
Hi iFixit community,
I have a problem. Seemingly at random, my mid-2012 Macbook Air locks up, the screen glitches out, and quickly crashes. When the speakers are on, I also get some awful sounds coming out. This happens regardless of being plugged into power or not, though it does seem to occur more rapidly while on battery. I’ve attached a video of the strange behavior.
I had previously (and carefully!) replaced the SSD and battery to keep it alive a few years back. Thinking those components might’ve been the culprit, I recently re-replaced both. It’s currently sporting an OWC SSD and fresh battery from iFixit.
I’ve tried looking in the machine logs and can’t find anything particularly useful. I’ve reset the SMC and PRAM many times. I’ve reinstalled a fresh MacOS just to be sure it wasn’t something weird in the kernel. Sadly, none of that has worked.
Anyone seen this before, or any ideas about what’s going on? Can I revive my favorite little computer?
Thanks folks!
Updates (from tests in comments):
- Model is an A1466, so mid-late 2012
- In addition to the issue happening on the built in display, it also occurs when using an external monitor exclusively (lid closed).
- Running a GPU benchmark tool did not crash it outright.
6 commentaires
@mattwilson - Your system is part of this series A1466 and more precisely MacBookAir5,2 - Mid 2012 models
You will see all of these use the Intel graphics engine: HD Graphics 4000 which is part of the CPU module. None of the Airs use dedicated GPU's like the Pro models do.
par Dan
I have exactly the same problem. My mac air is also mid-2012. Sometimes it flickers and crashes at the login screen, sometimes it runs several days without any problem. It is really random and tried many things but couldn’t fix the problem. Is there any new comments or suggestions on this issue ?
par Esra
I experienced the same thing with my mid 2012 MacBook Air luckily I upgraded to a 2019 MacBook Pro 13
par Ahmed Elbaz
Is there a way that you can take the bad GPU and put in a other one like it alright soldier in but. I’m wondering if u could unsolider it and responder the new on to it.
par Jordan Chapman
Resolider the new on to it with the old one?
par Jordan Chapman
Afficher 1 commentaire en plus
