Eclipse 180BL is a media player featuring a 1.8' LCD display.
This device is made by Mach Speed and is the "180BL Model".
To make sure you have this exact model please locate the name of the model on the back of the device.
This should be located in the middle, on the back, in white bold letters.
The one for this device reads : "Eclipse 180BL 8GB"
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
Malfunctioning battery
Malfunctioning charging circuit
Malfunctioning charging socket/connector and/or cable
Battery replacement tutorial at:
Eclipse 180BL Battery Replacement
Replacing battery without confirming viability of the unit's other components is not guaranteed to fix your non-charging problem.
par prop man
