Aller au contenu principal
Modèle A1312 / Mid-2011 / processeur 2.7 & 3.1 GHz Core i5 ou 3.4 GHz Core i7, ID iMac12,2
Questions au sujet de 687 Voir tout
Location of Apple SSD drive on iMac 2011 27" discovered
The custom configured iMac with an SSD drive hides the drive in a different place than it traditionally would be placed.
To find the Apple SSD drive check underneath the CD/DVD drive.
Répondre à cette question J'ai le même problème
Indice 3
Ajouter un commentaire
1 Réponse
Réponse la plus utile
The Apple installed 2.5” SSD is mounted on the studs under the optical drive
Indice 4
10 commentaires:
I wish I had this answer the other day before I followed various notes online and finally began digging below the Logic Board. I eventually found it the other day.
Finally right there under the Optical drive as you’ve wonderfully photographed it. Thank you for posting the photo for others, and potentially myself if I have a long day!
par
@danj have one of these on the bench that I bought. Am working on the GPU but ordered the cable for a 2.5" SSD. iMac Intel 27" (Mid 2011) Dual Hard Drive Kit / Upgrade Parts Only
My thinking was to just keep the old hard drive, thus I don't have to buy an OWC thermal sensor for $50 (maybe do a fusion drive setup).
Can I retain the optical AND add an SSD?
par
@mayer - Yes! There is a third SATA port on the logic board. The guide will aim you to the spare port Installation d'un second disque dur (HDD ou SSD) dans l'iMac Intel 27" EMC 2429
par
@danj Thanks, just got the cable in today. Do you know about this GPU replacement. I could not get the seller to respond to my email about it already being flashed. Seems like a much better alternative than putting an expensive Apple one in again that is likely to fail.
par
@mayer What GPU replacement??
I use these TheBookYard - GPU's (exchanged)
par
Voir 5 commentaires en plus
Ajouter une réponse
Wizdom On Wheels sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 20
Total : 525
