What's up with my compressor?
Here are the symptoms in my side by side Frigidaire: fridge and freezer cool, but not cold enough - freezer is above freezing. I can hear the fan running in the freezer and cold-ish air comes out. Underneath everything is clean and the fan is running. The compressor tank is room temperature. Every minute or two I hear the compressor turn on and run for several seconds and then turn off again. It sounds somewhat noisy, probably too noisy, but I don’t know how loud it should be since I have never heard it pulled out of the cabinet with the back off before. Also, if it is the compressor, can I replace it does a professional need to because refrigerant will need to be recovered/added? Thanks for any input.
1 commentaire
Yes it could be your unit is losing coolant and unless you have the necessary equipment to seal the leak, test the pressure, add coolant etc it will be necessary to call in a pro.
par prop man
