Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Repair guides and support for your Philips TV.
Questions au sujet de 143 Voir tout
Philips tv goes black right after philips logo on startup
Hi,
I have a Philips 40pft5300, this morning when I turned it on it gave me a flash of the philips logo and then turned black, I can see the shapes on the screen with a flashlight and sound goes trough fine. But no light! All of the led’s works fine, had it opened to see. I am kind of lost right now, and are worried for the voltage the led's get on startup? Is it normal to fly to 30+ volts and slowly fall down to 20 ish? Have posted as many pics as posible
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
3 solutions
Réponse la plus utile
@jensklj this “Is it normal to fly to 30+ volts and slowly fall down to 20 ish” makes me think you are having an issue with either the power board not providing proper voltage or the main board not sending a proper signal to turn the lights on. Measure the voltage on the connector from the power board to the main board and let us know what those are. Of course it could always be the backlight array but I want you to be reasonably sure.
Cette réponse a-t-elle été utile ?
Indice 1
CArefully look if the capacitors are ‘bulged’ or leaky? If yes, u need to solder them. (they cost only 1-2 $)
Indice 0
Hi @jensklj
I have worked on TV’s in the past with your exact issue . I tried every board replacement because the back lights worked fine, but it didn’t fix the problem.
What you need are a new set of back light strips. Even though they work fine, they are starting to fail in a way that draws too many amps from the power supply. This is why they are cut off right after working for a split second. Once they are replaced, the TV should work fine.
I recommend taking a look at Shop Jimmy for replacement parts. They make new strips that are intended to last longer than the original.
Indice 0
Ajouter une réponse
Jens Jensen sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 2
7 derniers jours : 50
30 derniers jours : 246
Total : 3,915
